[Qgis-user] problems using grass plugin in Qgis 1.8
Map_Daddy
petefinch36 at gmail.com
Thu Aug 8 12:01:40 PDT 2013
Hello
I have been trying to use the grass plugin for Qgis but I keep getting this
error every time I try and use a grass tool.
"Cannot start module"
"Command
C:\OSGeo4W\apps\grass\grass-6.4.3\bin/v.clean.exe--interference-description"
I'm thinking the problem is with the forward slash in the path. I get a
forward slash in the path for every tool I have tried. Not Sure how to fix
this.
here is my version info:
QGIS version
1.8.0-Lisboa
QGIS code revision
43f0c7b
Compiled against Qt
4.7.1
Running against Qt
4.7.1
Compiled against GDAL/OGR
1.9.2
Running against GDAL/OGR
1.9.2
GEOS Version
3.3.8
PostgreSQL Client Version
8.3.10
SpatiaLite Version
4.1.1
QWT Version
5.2.1
This copy of QGIS writes debugging output.
View this message in context: http://osgeo-org.1560.x6.nabble.com/problems-using-grass-plugin-in-Qgis-1-8-tp5071605.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
