[Qgis-user] Activating Label Tools
Lene Fischer lfi at life.ku.dk
Sun Aug 11 14:37:07 PDT 2013
Hi Alex
First - I love the new labeling - It is all I needed to a label function - now I only need the function to move the labels individually.
So I´m sorry to say, but the tools will not be activated using the method you explain.  And I find no explonations in the manual.
Regards
Lene
________________________________________
Fra: Alex Mandel [tech_dev at wildintellect.com]
Sendt: 11. august 2013 23:26
Til: Lene Fischer
Cc: qgis-user
Emne: Re: [Qgis-user] Activating Label Tools
http://docs.qgis.org/2.0/html/en/docs/user_manual/working_with_vector/vector_properties.html#labels-menu
Right, in the first dialog you have to turn labels on and pick the
column. Once you have labels on screen and that layer is selected the
other buttons should be usable. In the advanced section there is
Data-Defined labelling, that might need to be activated for the tools
you want to work.
Thanks,
Alex
On 08/11/2013 02:15 PM, Lene Fischer wrote:
> Sorry I don´t understand.
> When I activate the left tool ( Layer labeling option) a dialog appears. But the toolbox does not activate.
> And what do you mean by "assign fields to store position"
> Is there a manual for this toolbox?
> Regards
> Lene Fischer
> Sendt: 11. august 2013 23:10
> Til: qgis-user
> Cc: Lene Fischer
> On 08/11/2013 01:56 PM, Lene Fischer wrote:
>> Hi
>> I´m trying to activate the tools at the Label box - ex Move label.
>> The layer is editable. Except for the first two tools all is gray and inactive.
>> How can I activate the tools.?
>> Regards
>> Lene Fischer
> Did you turn on labels (the first tool)? Then those other tools should
> be come active. Though in the first tool you have to assign fields to
> store position etc...
> Enjoy,
> Alex
> Qgis-user mailing list
