[Qgis-user] Feature count Master 31
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Aug 12 03:53:49 PDT 2013
Hi Lene,
This sounds like a bug; if you can confirm it on the 1.9.x branch (if
that's now what you're using now), you should report it here:
http://hub.qgis.org/projects/quantum-gis/issues
Jonathan
On 11 August 2013 15:39, Lene Fischer <lfi at life.ku.dk> wrote:
> Hi
> In *Layer>Show feature count *the numbers of features is shown in the
> legend.
> But after digitizing there is no update of the counts.
> I´ve tried to save - but still no results.
> Regards
> Lene Fischer
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/70f0deeb/attachment.html>
