[Qgis-user] Legend in Print Composer Master 31
Nathan Woodrow
madmanwoo at gmail.com
Mon Aug 12 04:06:04 PDT 2013
All good. I fixed it today.
On 12/08/2013 8:57 PM, "Jonathan Moules" <jonathanmoules at warwickshire.gov.uk>
wrote:
> Hi,
> The first sounds like a bug, I'd report it as such unless someone replies
> to the contrary on here. Can't help on the second I'm afraid.
> Bug reporting: http://hub.qgis.org/projects/quantum-gis/issues
> Jonathan
> On 11 August 2013 15:49, Lene Fischer <lfi at life.ku.dk> wrote:
>> Hi
>> First
>> I have a layer which is categorized. In the layer>legend there is an
>> empty signature - as always.
>> When I insert a legend in the print composer, the empty signature now is
>> shown with the layer name - not empty as in the layer legend.
>> Secondly
>> In the print composer>Legend Items I try to delete the Layers title. In
>> 1.8 I marked the text clicked in the pencil and deleted the text. In Master
>> 31 I can still do the same, but the text is not deleted. How can this be
>> done.
>> Regards
>> Lene Fischer
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/a8e1f575/attachment.html>
