[Qgis-user] Legend in Print Composer Master 31
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Mon Aug 12 03:57:06 PDT 2013
The first sounds like a bug, I'd report it as such unless someone replies
to the contrary on here. Can't help on the second I'm afraid.
Bug reporting: http://hub.qgis.org/projects/quantum-gis/issues
Jonathan
On 11 August 2013 15:49, Lene Fischer <lfi at life.ku.dk> wrote:
>  Hi
>  First
> I have a layer which is categorized. In the layer>legend there is an empty
> signature - as always.
> When I insert a legend in the print composer, the empty signature now is
> shown with the layer name - not empty as in the layer legend.
>  Secondly
> In the print composer>Legend Items  I try to delete the Layers title. In
> 1.8 I marked the text clicked in the pencil and deleted the text. In Master
> 31 I can still do the same, but the text is not deleted. How can this be
> done.
>  Regards
> Lene Fischer
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/fb8695da/attachment.html>
