[Qgis-user] Qgis-user Digest, Vol 90, Issue 36
Denis Rouzaud
denis.rouzaud at gmail.com
Mon Aug 12 06:37:51 PDT 2013
Félicitations!!!!!!!!!!!!!!!!!!!!
c'est cool!
contente????
pour le salaire, c'est vraiment dommage, j'ai bien entendu au téléphone
que t'allais pas le faire.
c'est pas encore trop tard, mais t'as loupé une belle coche.
t'auras pas grande crédibilité en rappelant: je veux bien mais vous
pouvez pas m'augmenter....
tu leur donnes quand la réponse?
On 08/12/2013 03:30 PM, qgis-user-request at lists.osgeo.org wrote:
> Send Qgis-user mailing list submissions to
> qgis-user at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> qgis-user-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Qgis-user digest..."
> Today's Topics:
> 1. Re: Legend in Print Composer Master 31 (Nathan Woodrow)
> 2. Re: Label using $area and decimals Master 31 (Nathan Woodrow)
> 3. Re: I could not run Qgis (Jos? Pedro Santos)
> 4. Co-ordinates (Geovicon)
> Message: 1
> Date: Mon, 12 Aug 2013 21:06:04 +1000
> From: Nathan Woodrow <madmanwoo at gmail.com>
> To: Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
> Cc: qgis-user <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] Legend in Print Composer Master 31
> Message-ID:
> <CAAi8Yg_2X=MrCoR7UuLFgHSupMmaxN9h4+=5L8Qp9aqM=suiSw at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> All good. I fixed it today.
> On 12/08/2013 8:57 PM, "Jonathan Moules" <jonathanmoules at warwickshire.gov.uk>
> wrote:
>> Hi,
>> The first sounds like a bug, I'd report it as such unless someone replies
>> to the contrary on here. Can't help on the second I'm afraid.
>> Bug reporting: http://hub.qgis.org/projects/quantum-gis/issues
>> Jonathan
>> On 11 August 2013 15:49, Lene Fischer <lfi at life.ku.dk> wrote:
>>> Hi
>>> First
>>> I have a layer which is categorized. In the layer>legend there is an
>>> empty signature - as always.
>>> When I insert a legend in the print composer, the empty signature now is
>>> shown with the layer name - not empty as in the layer legend.
>>> Secondly
>>> In the print composer>Legend Items I try to delete the Layers title. In
>>> 1.8 I marked the text clicked in the pencil and deleted the text. In Master
>>> 31 I can still do the same, but the text is not deleted. How can this be
>>> done.
>>> Regards
>>> Lene Fischer
>>> Qgis-user at lists.osgeo.org
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/a8e1f575/attachment-0001.html>
> Message: 2
> Date: Mon, 12 Aug 2013 21:14:35 +1000
> Subject: Re: [Qgis-user] Label using $area and decimals Master 31
> Message-ID:
> <CAAi8Yg-fKQTBOMZFcJn+Uj0FRN+HsfKOu_A7u88AE6HNY=8oAw at mail.gmail.com>
> This is the ticket that was opened for it
> http://hub.qgis.org/issues/8447however I closed it because it's not
> really a bug because you can't format
> a string as a number.
> On 12/08/2013 9:03 PM, "Jonathan Moules" <jonathanmoules at warwickshire.gov.uk>
> wrote:
>> Hi,
>> Possibly this? http://hub.qgis.org/issues/8405 - it was fixed a few days
>> ago apparently so if it is still happening in a new build it sounds like a
>> different bug.
>> Also maybe - http://hub.qgis.org/issues/5546 - unfixed.
>> Jonathan
>> On 11 August 2013 16:31, Lene Fischer <lfi at life.ku.dk> wrote:
>>> Hi Larry
>>> The decimal funcion works fine - if I only choose the $area function.
>>> But when I add another field or 'text' the number of decimals expand.
>>> Regards
>>> Lene Fischer
>>> *Fra:* larry at shafferinteractive.com [larry at shafferinteractive.com] p?
>>> vegne af Larry Shaffer [larrys at dakotacarto.com]
>>> *Sendt:* 8. august 2013 05:56
>>> *Til:* Lene Fischer
>>> *Cc:* qgis-user at lists.osgeo.org
>>> *Emne:* Re: [Qgis-user] Label using $area and decimals
>>> Hi Lene,
>>> On Wed, Aug 7, 2013 at 9:09 PM, Lene Fischer <lfi at life.ku.dk> wrote:
>>>> Hello
>>>> In Master I?m trying to set a label with the function $area. This works
>>>> fine.
>>>> But I?m trying to use the formatting for numbers with only 1 decimal -
>>>> no succes.
>>> Hmm. I just tried setting the expression to $area and using the
>>> 'Formatted numbers' option for the layer: worked. I also used just an
>>> expression:
>>> format_number( $area, 3)
>>> and that worked too, even where the area result was a whole integer,
>>> i.e. label was 12.000. I tested with precision of '1' and both worked fine.
>>> Can you share the data, even if it is just a file containing the individual
>>> feature that is not labeling properly?
>>>> It works fine if I use a coloumn containing the area.
>>> But this is not a solution because the $area is not dynamic in the
>>>> coloum of the attribut table.
>>>> Secondly - how do I activate the functions in the Labeltoolbar -ex
>>>> Move or Show/Hide
>>> New documentation for labeling canvas map tools is forthcoming. For
>>> now, you can reference:
>>> http://gis.stackexchange.com/questions/67408
>>> Regards,
>>> Larry
>>>> Regards
>>>> Lene Fischer
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/507503bd/attachment-0001.html>
> Message: 3
> Date: Mon, 12 Aug 2013 11:37:08 +0000
> From: Jos? Pedro Santos <zpsantos1 at hotmail.com>
> To: "Dr. Md. Manirul Islam" <ted at icddrb.org>
> Cc: QGIS Mailing List <qgis-user at lists.osgeo.org>
> Subject: Re: [Qgis-user] I could not run Qgis
> Message-ID: <DUB110-W13251236D3BA1AB0C1FE987E05B0 at phx.gbl>
> Hi,
> Are you using the standalone installer or the OSGeo4w Installer? If is the second one, delete the folders related with qgis, sextante... and then try again.
> Good Luck,
> Jos? Santos
> From: ted at icddrb.org
> To: madmanwoo at gmail.com; goyodiaz at gmail.com
> Date: Mon, 12 Aug 2013 09:41:03 +0000
> CC: qgis-user at lists.osgeo.org
> I have down loaded but could not run QGIS. Please help.
> From: Nathan Woodrow [mailto:madmanwoo at gmail.com]
> Sent: Monday, August 12, 2013 3:33 PM
> To: Goyo
> Cc: Dr. Md. Manirul Islam; qgis-user at lists.osgeo.org
> On Mon, Aug 12, 2013 at 7:28 PM, Goyo <goyodiaz at gmail.com> wrote:
> I'm unable to tell what's going on in your case but nircmd.exe is not
> needed to run QGIS.
> Yes nircmd is used to run QGIS without showing the command window that setups up that paths.
> - Nathan
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/e3cba45f/attachment-0001.html>
> Message: 4
> Date: Mon, 12 Aug 2013 15:18:49 +0200
> From: "Geovicon" <geovicon at iafrica.com>
> To: <qgis-user at lists.osgeo.org>
> Subject: [Qgis-user] Co-ordinates
> Message-ID: <000301ce975e$7c951c70$75bf5550$@com>
> Content-Type: text/plain; charset="us-ascii"
> To whom it may concern
> We are struggling to work with co-ordinates in Quantum GIS.
> How do we get the co-ordinates in a form that is acceptable to QGIS ?
> Please send an example of a .csv file and inform us how to import/open it in
> QGIS.
> What is the method if only one co-ordinate want to be used ?
> These things are not clear in the manual.
> Thanks
> Geovicon Environmental (Pty) Ltd
> Tel: 013 243 0542
> Fax: 086 632 4936
> URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130812/4c765695/attachment.html>
> End of Qgis-user Digest, Vol 90, Issue 36
