[Qgis-user] Map doesn't appear in the Composer
Annisa Indah Sari
annisaindah at hotmail.com
Tue Aug 13 19:54:59 PDT 2013
Hi QGIS users,
I use QGIS 1.8 and not a new user but just met this situation below:
My map doesn't appear in the Composer after I clicked "Add New Map". I checked the scale, the map projection, and the data frame projection are all correct. I have been trying to check and uncheck the "Control rendering order" and "render". And also check the map scale in the composer. All are correct. But why does the map still not appear?
Thanks.
Annisa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/68c22472/attachment.html>
