[Qgis-user] Map doesn't appear in the Composer
Stott James fmrojst at fylkesmannen.no
Tue Aug 13 22:46:37 PDT 2013
Apologies if you have tried this already but you don't mention it, but did you click the 'Set to map canvas extent' button?
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne av Annisa Indah Sari
Sendt: 14. august 2013 04:55
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] Map doesn't appear in the Composer
Hi QGIS users,
I use QGIS 1.8 and not a new user but just met this situation below:
My map doesn't appear in the Composer after I clicked "Add New Map". I checked the scale, the map projection, and the data frame projection are all correct. I have been trying to check and uncheck the "Control rendering order" and "render". And also check the map scale in the composer. All are correct. But why does the map still not appear?
Thanks.
Annisa
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130814/8eff3637/attachment.html>
