[Qgis-user] Labels window goes out the visible area of monitor
Carlos Cerdán
sig.upagu at gmail.com
Thu Aug 15 08:01:43 PDT 2013
Issue solved, It works!.
Thank you Nathan and Jonathan. The Modulo operator is new for me.
Regards
Carlos
2013/8/15 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
> Exactly what I was thinking, though wouldn't you want the modulo to be 200
> in this case (you used 400 in your example)?
> Carlos - the advantage of this is it will automagically work for all
> heights, even mount Everest or the Mariana Trench.
> Cheers,
> Jonathan
> On 15 August 2013 15:08, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>> or you can use the Modulo operator ;)
>> CASE WHEN Z_msnm % 400 = 0 THEN Z_msnm END
>> - Nathan
>> On Fri, Aug 16, 2013 at 12:04 AM, Carlos Cerdán <sig.upagu at gmail.com>wrote:
>>> Hi dear group
>>> I have a topographic layer that I want to put labels when the contour is
>>> multiplo of 200. I got it with this large conditional sentence:
>>> case
>>> when ("Z_msnm" =200 OR "Z_msnm" =400 OR "Z_msnm" =600 OR "Z_msnm" =800
>>> OR "Z_msnm" =1000 OR "Z_msnm" =1200 OR "Z_msnm" =1400 OR "Z_msnm" =1600 OR
>>> "Z_msnm" =1800 OR "Z_msnm" =2000 OR "Z_msnm" =2200 OR "Z_msnm" =2400 OR
>>> "Z_msnm" =2600 OR "Z_msnm" =2800 OR "Z_msnm" =3000 OR "Z_msnm" =3200 OR
>>> "Z_msnm" =3400 OR "Z_msnm" =3600 OR "Z_msnm" =3800 OR "Z_msnm" =4000 OR
>>> "Z_msnm" =4200 OR "Z_msnm" =4400 OR "Z_msnm" =4600 OR "Z_msnm" =4800 OR
>>> "Z_msnm" =5000 OR "Z_msnm" =5200 OR "Z_msnm" =5400 OR "Z_msnm" =5600 OR
>>> "Z_msnm" =5800 OR "Z_msnm" =6000 OR "Z_msnm" =6200 OR "Z_msnm" =6400 OR
>>> "Z_msnm" =6600 OR "Z_msnm" =6800) then "Z_msnm"
>>> end
>>> After to do this condition all was ok, but an issue appear: the "label
>>> layer configuration window" tries to show the condition in one line only,
>>> so the width of this window is so long that the right part of this window
>>> goes out of monitor visible area.
>>> Is there some way to avoid this?. It happens even if each condition is
>>> in diferent lines (QGIS 1.8 on Ubuntu 12.04 and Windows 7).
>>> Is there another smaller condition to use instead that the one I made?
>>> Thank you in advance for any help
>>> ------ 8< --- Spanish version ---
>>> Hola estimado grupo:
>>> Tengo una capa topográfica a la cual deseo colocar etiquetas en las
>>> curvas de nivel múltiplo de 200. Esto lo hice con la condición mostrada
>>> arriba.
>>> case
>>> when ("Z_msnm ... etc
>>> end
>>> La condición trabaja bien, pero aparece un problema: la ventana de
>>> "configuración del etiquetado de la capa" muestra la condición en una sola
>>> línea, así que el ancho es tan grande que la parte derecha de esta ventana
>>> sale fuera del área visible del monitor.
>>> ¿Existe alguna manera de evitar esto? Esto sucede inclusive si cada
>>> condición está en una línea diferente ( QGIS 1.8 en Ubuntu 12.04 y Windows
>>> 7).
>>> ¿Hay alguna condición más corta que podría utilizar en lugar de la que
>>> hice?
>>> Gracias de antemano por cualquier ayuda
>>> ------ 8< -------
>>> Carlos Cerdán
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130815/9047e169/attachment.html>
