[Qgis-user] Labels window goes out the visible area of monitor
Carlos Cerdán
sig.upagu at gmail.com
Thu Aug 15 08:28:21 PDT 2013
It works for conditional styles also, but just with:
Z_msnm % 200 = 0
Thank you again, and sorry for my poor knowledge of SQL
Carlos
2013/8/15 Carlos Cerdán <sig.upagu at gmail.com>
> Issue solved, It works!.
> Thank you Nathan and Jonathan. The Modulo operator is new for me.
> Regards
> Carlos
> 2013/8/15 Jonathan Moules <jonathanmoules at warwickshire.gov.uk>
>> Exactly what I was thinking, though wouldn't you want the modulo to be
>> 200 in this case (you used 400 in your example)?
>> Carlos - the advantage of this is it will automagically work for all
>> heights, even mount Everest or the Mariana Trench.
>> Cheers,
>> Jonathan
>> On 15 August 2013 15:08, Nathan Woodrow <madmanwoo at gmail.com> wrote:
>>> or you can use the Modulo operator ;)
>>> CASE WHEN Z_msnm % 400 = 0 THEN Z_msnm END
>>> - Nathan
>>> On Fri, Aug 16, 2013 at 12:04 AM, Carlos Cerdán <sig.upagu at gmail.com>wrote:
>>>> Hi dear group
>>>> I have a topographic layer that I want to put labels when the contour
>>>> is multiplo of 200. I got it with this large conditional sentence:
>>>> case
>>>> when ("Z_msnm" =200 OR "Z_msnm" =400 OR "Z_msnm" =600 OR "Z_msnm" =800
>>>> OR "Z_msnm" =1000 OR "Z_msnm" =1200 OR "Z_msnm" =1400 OR "Z_msnm" =1600 OR
>>>> "Z_msnm" =1800 OR "Z_msnm" =2000 OR "Z_msnm" =2200 OR "Z_msnm" =2400 OR
>>>> "Z_msnm" =2600 OR "Z_msnm" =2800 OR "Z_msnm" =3000 OR "Z_msnm" =3200 OR
>>>> "Z_msnm" =3400 OR "Z_msnm" =3600 OR "Z_msnm" =3800 OR "Z_msnm" =4000 OR
>>>> "Z_msnm" =4200 OR "Z_msnm" =4400 OR "Z_msnm" =4600 OR "Z_msnm" =4800 OR
>>>> "Z_msnm" =5000 OR "Z_msnm" =5200 OR "Z_msnm" =5400 OR "Z_msnm" =5600 OR
>>>> "Z_msnm" =5800 OR "Z_msnm" =6000 OR "Z_msnm" =6200 OR "Z_msnm" =6400 OR
>>>> "Z_msnm" =6600 OR "Z_msnm" =6800) then "Z_msnm"
>>>> end
>>>> After to do this condition all was ok, but an issue appear: the "label
>>>> layer configuration window" tries to show the condition in one line only,
>>>> so the width of this window is so long that the right part of this window
>>>> goes out of monitor visible area.
>>>> Is there some way to avoid this?. It happens even if each condition is
>>>> in diferent lines (QGIS 1.8 on Ubuntu 12.04 and Windows 7).
>>>> Is there another smaller condition to use instead that the one I made?
>>>> Thank you in advance for any help
>>>> ------ 8< --- Spanish version ---
>>>> Hola estimado grupo:
>>>> Tengo una capa topográfica a la cual deseo colocar etiquetas en las
>>>> curvas de nivel múltiplo de 200. Esto lo hice con la condición mostrada
>>>> arriba.
>>>> case
>>>> when ("Z_msnm ... etc
>>>> end
>>>> La condición trabaja bien, pero aparece un problema: la ventana de
>>>> "configuración del etiquetado de la capa" muestra la condición en una sola
>>>> línea, así que el ancho es tan grande que la parte derecha de esta ventana
>>>> sale fuera del área visible del monitor.
>>>> ¿Existe alguna manera de evitar esto? Esto sucede inclusive si cada
>>>> condición está en una línea diferente ( QGIS 1.8 en Ubuntu 12.04 y Windows
>>>> 7).
>>>> ¿Hay alguna condición más corta que podría utilizar en lugar de la que
>>>> hice?
>>>> Gracias de antemano por cualquier ayuda
>>>> ------ 8< -------
>>>> Carlos Cerdán
>>>> _______________________________________________
>>>> Qgis-user mailing list
>>>> Qgis-user at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> This transmission is intended for the named addressee(s) only and may
>> contain sensitive or protectively marked material up to RESTRICTED and
>> should be handled accordingly. Unless you are the named addressee (or
>> authorised to receive it for the addressee) you may not copy or use it, or
>> disclose it to anyone else. If you have received this transmission in error
>> please notify the sender immediately. All email traffic sent to or from us,
>> including without limitation all GCSX traffic, may be subject to recording
>> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130815/621cb8df/attachment.html>
