[Qgis-user] Large raster datasets in 2.0
Stott James
fmrojst at fylkesmannen.no
Tue Aug 20 04:29:14 PDT 2013
Does this bug that has just been fixed solve any of your problems?
http://hub.qgis.org/issues/8356
I have lots of vrt files with overviews built, and they were taking forever to load in QGIS master. Now they open quickly again like in 1.8.
Fra: qgis-user-bounces at lists.osgeo.org [mailto:qgis-user-bounces at lists.osgeo.org] På vegne av Jonathan Moules
Sendt: 20. august 2013 13:10
Til: qgis-user at lists.osgeo.org
Emne: [Qgis-user] Large raster datasets in 2.0
Hi list,
We have some large raster datasets that are mosaiced into a single product. QGIS 1.7 (and I think 1.8) could access these in JP2 or ECW, but 2.0 doesn't seem to be able to (or maybe that's a limitation of the weeklies and the final thing will be compiled with it?).
Due to the size of the rasters combined with a bug in GDAL that causes it to take literally a month to process the overviews for super-large rasters (about 450,000 * 440,000), we can't create them as a GeoTIFF.
So the question - how do I use super-large rasters as a single contiguous dataset in QGIS 2?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130820/4c432d55/attachment.html>
