[Qgis-user] Large raster datasets in 2.0
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Aug 20 04:40:40 PDT 2013
Hi Kris,
  The WMS is a cunning plan but this is going into a location (a fire
command vehicle) where simplicity is key; setting up a GeoServer instance
would add complexity that would require maintainence. Also QGIS 2.0 seems a
little flaky with WMS, at least for us. A single file would be optimal.
I do understand the use of JP2 and ECW for such large datasets, should work
> fine too actually.
QGIS 2.0, or at least the weekly builds, doesn't include support for either
of these two formats as far as I can tell otherwise I'd just use them and
save myself the bother of conversion.
I'll have to look into the VRT stuff - I've not tried them before.
Thanks,
Jonathan
On 20 August 2013 12:27, Kris Nackaerts <knackaerts at gmx.net> wrote:
> Hi,
> I would serve them as WMS via geoserver if that is an option. That's how
> we do it at the research institute I work. You could tile them in tiles of
> reasobale size first. Geoserver is easy to setup and configure, again, if
> that is an option.
> What I also use for larger datasets is gdal VRT: keep the imagery tiled,
> create one single image as a virtual dataset. I do understand the use of
> JP2 and ECW for such large datasets, should work fine too actually.
> Regards and good luck,
> Kris Nackaerts
> *Gesendet:* Dienstag, 20. August 2013 um 13:10 Uhr
> *Von:* "Jonathan Moules" <jonathanmoules at warwickshire.gov.uk>
> *An:* qgis-user at lists.osgeo.org
> *Betreff:* [Qgis-user] Large raster datasets in 2.0
> Hi list,
>   We have some large raster datasets that are mosaiced into a single
> product. QGIS 1.7 (and I think 1.8) could access these in JP2 or ECW, but
> 2.0 doesn't seem to be able to (or maybe that's a limitation of the
> weeklies and the final thing will be compiled with it?).
> Due to the size of the rasters combined with a bug in GDAL that causes it
> to take literally a month to process the overviews for super-large rasters
> (about 450,000 * 440,000), we can't create them as a GeoTIFF.
> So the question - how do I use super-large rasters as a single contiguous
> dataset in QGIS 2?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130820/2a39fcc2/attachment.html>
