[Qgis-user] Testing OSGeo4W 64bit
Jürgen E. Fischer
jef at norbit.de
Mon Aug 26 00:08:10 PDT 2013
Hi Andreas,
On Mon, 26. Aug 2013 at 09:01:47 +0200, Andreas Neumann wrote:
> Question: can this coexist with the 32bit installation? Or should I
> first remove the 32bit installation. This is only relevant during
> testing now. Later I will switch to 64bit only, anyway.
Not in the same directory, but otherwise yes. So you should use a separate
directory for the 64bit install (I use C:\OSGeo4W64). In the included
installer you can also use a different start menu name for the 64 bit install -
otherwise the shortcuts will get overwritten.
Jürgen
Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
Software Engineer D-26506 Norden http://www.norbit.de
QGIS PSC member (RM) IRC: jef on FreeNode
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
