[Qgis-user] Testing OSGeo4W 64bit
Ramon Andiñach
custard at westnet.com.au
Mon Aug 26 03:31:24 PDT 2013
Hi Jürgen,
I think I'm missing something somehow.
I've downloaded the installer, run the installer and gone into advanced and clicked on experimental. However, I'm not seeing the 64-bit versions or anything that looks different to the 32-bit installer.
I did tell it to install into a different path, so that I didn't damage my 32-bit installs, but I'm being told everything is up to date.
Bit confused, and wondering if I could get some help?
-ramon.
On 25/08/2013, at 23:58 , Jürgen E. Fischer wrote:
> Hi there,
> I've prepared a 64bit build of major parts of OSGeo4W.
> My main focus was QGIS (1.8 and master), but it also has all of it's numerous
> dependencies including current versions of GRASS 6.4 (w/o Tk), GEOS, PROJ.4,
> Qt, python, GDAL (including plugins for Oracle, ECW, MrSID and FileGDB support)
> and more.
> The installer is available at http://trac.osgeo.org/osgeo4w/ (marked as
> Experimental 64bit [1]).
> Please test and report.
> Jürgen
> [1] http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup.exe
> Jürgen E. Fischer norBIT GmbH Tel. +49-4931-918175-31
> Dipl.-Inf. (FH) Rheinstraße 13 Fax. +49-4931-918175-50
> Software Engineer D-26506 Norden http://www.norbit.de
> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
> Rheinstrasse 13, 26506 Norden
> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
> Qgis-user mailing list
