[Qgis-user] Testing OSGeo4W 64bit
Andreas Neumann a.neumann at carto.net
Mon Aug 26 04:03:58 PDT 2013
Hi Ramon,
Did you really download the 64bit installer? Here is the direct URL:
http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup.exe
You don't see any difference between the two installers and you don't
see it in the about screen of QGIS which version you are running (32bit
or 64bit) - unless I overlooked something.
Andreas
Am 26.08.2013 12:31, schrieb Ramon Andiñach:
> Hi Jürgen,
> I think I'm missing something somehow.
> I've downloaded the installer, run the installer and gone into advanced and clicked on experimental. However, I'm not seeing the 64-bit versions or anything that looks different to the 32-bit installer.
> I did tell it to install into a different path, so that I didn't damage my 32-bit installs, but I'm being told everything is up to date.
> Bit confused, and wondering if I could get some help?
> -ramon.
> On 25/08/2013, at 23:58 , Jürgen E. Fischer wrote:
>> Hi there,
>> I've prepared a 64bit build of major parts of OSGeo4W.
>> My main focus was QGIS (1.8 and master), but it also has all of it's numerous
>> dependencies including current versions of GRASS 6.4 (w/o Tk), GEOS, PROJ.4,
>> Qt, python, GDAL (including plugins for Oracle, ECW, MrSID and FileGDB support)
>> and more.
>> The installer is available at http://trac.osgeo.org/osgeo4w/ (marked as
>> Experimental 64bit [1]).
>> Please test and report.
>> Jürgen
>> [1] http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup.exe
>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>> Software Engineer         D-26506 Norden               http://www.norbit.de
>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>> Rheinstrasse 13, 26506 Norden
>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
