[Qgis-user] Testing OSGeo4W 64bit
    Ramon Andiñach
    custard at westnet.com.au
    Mon Aug 26 06:10:18 PDT 2013
Hi Andreas,
Thanks, I had the right installer, but it looks like I'd changed where to put the shortcuts but not where to put programme so the installer was being correct. (ie, the 64-bit version is the same as the 32-bit I already had installed, so nothing to do).
I've got something installed now, and some initial thoughts would be:
(and on the grand scheme of things these aren't really important for testing)
- Wow, cool! Thanks Jürgen.
- I'd really like some way of telling if I have a 32 or 64-bit version running.
- I'd really like some way of telling the two installers apart. (Will I break things if I locally rename the 64-bit one?)
- The shortcuts appear to be turning up in the "normal" OSGeo4W shortcut folder rather than the OSG4W64 one I asked the installer to use. The installer did make the folder, just doesn't seem to be using it.
It's late for me now, so I'm looking forward to opening up some big rasters tomorrow :)
-ramon.
On 26/08/2013, at 19:03 , Andreas Neumann wrote:
> Hi Ramon,
> Did you really download the 64bit installer? Here is the direct URL:
> http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup.exe
> You don't see any difference between the two installers and you don't
> see it in the about screen of QGIS which version you are running (32bit
> or 64bit) - unless I overlooked something.
> Andreas
> Am 26.08.2013 12:31, schrieb Ramon Andiñach:
>> Hi Jürgen,
>> I think I'm missing something somehow.
>> I've downloaded the installer, run the installer and gone into advanced and clicked on experimental. However, I'm not seeing the 64-bit versions or anything that looks different to the 32-bit installer.
>> I did tell it to install into a different path, so that I didn't damage my 32-bit installs, but I'm being told everything is up to date.
>> Bit confused, and wondering if I could get some help?
>> -ramon.
>> On 25/08/2013, at 23:58 , Jürgen E. Fischer wrote:
>>> Hi there,
>>> I've prepared a 64bit build of major parts of OSGeo4W.
>>> My main focus was QGIS (1.8 and master), but it also has all of it's numerous
>>> dependencies including current versions of GRASS 6.4 (w/o Tk), GEOS, PROJ.4,
>>> Qt, python, GDAL (including plugins for Oracle, ECW, MrSID and FileGDB support)
>>> and more.
>>> The installer is available at http://trac.osgeo.org/osgeo4w/ (marked as
>>> Experimental 64bit [1]).
>>> Please test and report.
>>> Jürgen
>>> [1] http://download.osgeo.org/osgeo4w/testing64/osgeo4w-setup.exe
>>> Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
>>> Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
>>> Software Engineer         D-26506 Norden               http://www.norbit.de
>>> norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
>>> Rheinstrasse 13, 26506 Norden
>>> GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
