[Qgis-user] QuickMultiAttributeEdit -- QGIS 1.9 master
Alexandre Neto
senhor.neto at gmail.com
Mon Aug 26 06:13:43 PDT 2013
Sandro,
In here (win7), if you did not set your active layer as editable, the
plugin will do it for you.
Best regards,
Alexandre Neto
On Mon, Aug 26, 2013 at 1:04 PM, Sandro Pellicciotta <
sandro.pellicciotta.gis at gmail.com> wrote:
> ok! there's my error...
> I didn't toggle the edit button before edit elements with the plugin...but
> into a blog (owned by the developer I think: *
> http://pvanb.wordpress.com/2012/02/18/quick-multi-attribute-edit-in-qgis/
> *) i red: "you should toggle the edit mode for the layer. If you forgot
> to do so, the plugin will remind you."
> ...the plugin didn't remind me anything!
> maybe should be interesting for the developers!
> 2013/8/26 Sandro Pellicciotta <sandro.pellicciotta.gis at gmail.com>
>> hi there!
>> Maybe I had a misunderstanding but...this plugins allow to edit a
>> specific (and equal for each one) column value for all the element
>> selected from the layer just in one click!...it's right?
>> if it's right it doesen't work...I don't think i've made errors it looks
>> too simple to fail (the least famous words...)
>> anyone has some opinion?
>> See you,
>> Sandro.
> Qgis-user mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130826/a9fa3159/attachment.html>
