[Qgis-user] ERROR Compiling QGIS 1.8 on Arch after updated python2-sip
Saulteau Don
sault.don at gmail.com
Tue Aug 27 14:18:16 PDT 2013
http://hub.qgis.org/issues/8507
Bug reported.
On Tue, Aug 27, 2013 at 2:12 AM, Vincent Schut <schut at sarvision.nl> wrote:
> Hi,
> just to confirm this: the same happens to me (also on Arch). I tried
> downgrading sip and python2-sip to 4.14, but that dit not work. Maybe
> because QT/QScintilla is bound to a certain sip version? I did get a
> error in ccmake about qscintilla and sip using different sip api's (10
> vs 10.1 if I recall correctly). I don't feel like downgrading the
> entire QT stack...
> Should we file a bug?
> Best,
> Vincent.
> On Mon, 26 Aug 2013 20:06:37 -0700
> Saulteau Don <sault.don at gmail.com> wrote:
>> I've been trying to compile QGIS 1.8 on Arch Linux x64 after
>> python2-sip was updated and now there's an error at about 94% I think
>> is related to the updated sip package but not sure.
>> Scanning dependencies of target python_module_qgis_core
>> [ 94%] Building CXX object
>> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart0.cpp.o
>> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart1.cpp.o
>> python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart2.cpp.o
>> In file included from
>> /home/saultdon/Development/aur/qgis/src/qgis-1.8.0/python/core/qgsmaplayerregistry.sip:10:0:
>> /home/saultdon/Development/aur/qgis/src/qgis-1.8.0/python/../src/core/qgsmaplayerregistry.h:
>> In member function ‘virtual void
>> sipQgsMapLayerRegistry::connectNotify(const char*)’:
>> /home/saultdon/Development/aur/qgis/src/qgis-1.8.0/python/../src/core/qgsmaplayerregistry.h:176:10:
>> error: ‘virtual void QgsMapLayerRegistry::connectNotify(const char*)’
>> is private
>> void connectNotify( const char * signal );
>> /home/saultdon/Development/aur/qgis/src/build/python/core/sipcorepart2.cpp:33967:46:
>> error: within this context
>> return;
>> make[2]: ***
>> [python/CMakeFiles/python_module_qgis_core.dir/core/sipcorepart2.cpp.o]
>> Error 1 make[1]: ***
>> [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2 make: ***
>> [all] Error 2 ==> ERROR: A failure occurred in build().
>> Aborting...
>> Do I need to downgrade python2-sip? It's at version 4.15.1 right now.
>> ==> Starting build()...
>> -- Looking for openpty - found
>> -- Found Proj: /lib64/libproj.so
>> -- Found GEOS: /usr/lib/libgeos_c.so
>> -- Found GDAL: /usr/lib/libgdal.so (1.10.0)
>> -- Found Expat: /lib64/libexpat.so
>> -- Found Spatialindex: /usr/lib64/libspatialindex.so
>> -- Found Qwt: /usr/lib64/libqwt.so (6.0.2)
>> -- Found Sqlite3: /lib64/libsqlite3.so
>> -- Found PostgreSQL: /usr/lib/libpq.so
>> -- Found SpatiaLite: /lib64/libspatialite.s
>> -- Found PythonInterp: /usr/bin/python2 (found version "2.7.5")
>> -- Found Python executable: /usr/bin/python2
>> -- Found Python version: 2.7.5
>> -- Found Python library: /usr/lib/libpython2.7.so
>> -- Found SIP version: 4.15.1
>> -- Found PyQt4 version: 4.10.3
>> -- Found GSL: -L/usr/lib -lgsl -lgslcblas -lm
>> -- txt2tags not found - disabled
>> -- Configuring done
>> -- Generating done
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
