[Qgis-user] Error compiling the qgis-server
Andrea Peri
aperi2007 at gmail.com
Tue Aug 27 15:15:09 PDT 2013
Hi, try-ing to compile from last trunk on my RedHat server I'm have this
error:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/QtCoremod.sip:130:
%OptionalInclude is deprecated, use %Include and the 'optional' argument
instead
/usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations should
not be used in explicit C/C++ signatures
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
Annotations should not be used in explicit C/C++ signatures
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
%GetCode should be used a sub-directive
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
%Module version number should be specified using the 'version' argument
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
instead
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
%AccessCode should be used a sub-directive
sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
/usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version number
sip: QGraphicsEffect has not been defined
make[2]: *** [python/core/sipcorepart0.cpp] Error 1
make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
make: *** [all] Error 2
Any thought ?
thx
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130828/ff475603/attachment.html>
