[Qgis-user] Error compiling the qgis-server
Saulteau Don
sault.don at gmail.com
Tue Aug 27 18:20:37 PDT 2013
There's been a bug filed at http://hub.qgis.org/issues/8507 that looks related.
What version of SIP are you running? On arch linux, it fails with
python2-sip v4.15.1 after sip was updated.
On Tue, Aug 27, 2013 at 3:15 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
> Hi, try-ing to compile from last trunk on my RedHat server I'm have this
> error:
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/QtCoremod.sip:130:
> %OptionalInclude is deprecated, use %Include and the 'optional' argument
> instead
> /usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations should
> not be used in explicit C/C++ signatures
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
> Annotations should not be used in explicit C/C++ signatures
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
> %GetCode should be used a sub-directive
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
> %Module version number should be specified using the 'version' argument
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
> instead
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
> %AccessCode should be used a sub-directive
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
> sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
> /usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version number
> sip: QGraphicsEffect has not been defined
> make[2]: *** [python/core/sipcorepart0.cpp] Error 1
> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
> make: *** [all] Error 2
> Any thought ?
> thx
> Andrea Peri
> qwerty àèìòù
> Qgis-user mailing list
