[Qgis-user] Error compiling the qgis-server
    aperi2007
    aperi2007 at gmail.com
    Tue Aug 27 23:30:33 PDT 2013
sorry, I have nt any python knowledgment.
How can I get the SIP version from python inside ?
On 28/08/2013 03:20, Saulteau Don wrote:
> There's been a bug filed at http://hub.qgis.org/issues/8507 that looks related.
> What version of SIP are you running? On arch linux, it fails with
> python2-sip v4.15.1 after sip was updated.
> On Tue, Aug 27, 2013 at 3:15 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>> Hi, try-ing to compile from last trunk on my RedHat server I'm have this
>> error:
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/QtCoremod.sip:130:
>> %OptionalInclude is deprecated, use %Include and the 'optional' argument
>> instead
>> /usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations should
>> not be used in explicit C/C++ signatures
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
>> Annotations should not be used in explicit C/C++ signatures
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
>> %GetCode should be used a sub-directive
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
>> %Module version number should be specified using the 'version' argument
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
>> instead
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
>> %AccessCode should be used a sub-directive
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
>> /usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version number
>> sip: QGraphicsEffect has not been defined
>> make[2]: *** [python/core/sipcorepart0.cpp] Error 1
>> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
>> make: *** [all] Error 2
>> Any thought ?
>> thx
>> Andrea Peri
>> qwerty àèìòù
>> Qgis-user mailing list
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
