[Qgis-user] Error compiling the qgis-server
    Saulteau Don
    sault.don at gmail.com
    Wed Aug 28 06:36:59 PDT 2013
It looks like you could open a python terminal and then issue the commands:
>>> import sip
>>> sip.SIP_VERSION_STR
'4.15.1' #this is the output
http://stackoverflow.com/questions/3524168/how-do-i-get-a-python-modules-version-number-through-code
On Tue, Aug 27, 2013 at 11:30 PM, aperi2007 <aperi2007 at gmail.com> wrote:
> sorry, I have nt any python knowledgment.
> How can I get the SIP version from python inside ?
> On 28/08/2013 03:20, Saulteau Don wrote:
>> There's been a bug filed at http://hub.qgis.org/issues/8507 that looks
>> related.
>> What version of SIP are you running? On arch linux, it fails with
>> python2-sip v4.15.1 after sip was updated.
>> On Tue, Aug 27, 2013 at 3:15 PM, Andrea Peri <aperi2007 at gmail.com> wrote:
>>> Hi, try-ing to compile from last trunk on my RedHat server I'm have this
>>> error:
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/QtCoremod.sip:130:
>>> %OptionalInclude is deprecated, use %Include and the 'optional' argument
>>> instead
>>> /usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations
>>> should
>>> not be used in explicit C/C++ signatures
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
>>> Annotations should not be used in explicit C/C++ signatures
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
>>> %GetCode should be used a sub-directive
>>> /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
>>> %Module version number should be specified using the 'version' argument
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
>>> instead
>>> /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
>>> %AccessCode should be used a sub-directive
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
>>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
>>> /usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version
>>> number
>>> sip: QGraphicsEffect has not been defined
>>> make[2]: *** [python/core/sipcorepart0.cpp] Error 1
>>> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error 2
>>> make: *** [all] Error 2
>>> Any thought ?
>>> thx
>>> Andrea Peri
>>> qwerty àèìòù
>>> Qgis-user mailing list
>>> Qgis-user at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-user
