[Qgis-user] Error compiling the qgis-server
Andrea Peri aperi2007 at gmail.com
Wed Aug 28 06:59:23 PDT 2013
Hi, thx for help.
this morning early our server was update.
After this update the compile will end without any problem.
I guess effectively was a problem of SIP. An too much old version of SIP.
Now the new version as reported from our python code is:
4.14.1
Thx, again.
Andrea.
2013/8/28 Saulteau Don <sault.don at gmail.com>
> It looks like you could open a python terminal and then issue the commands:
> >>> import sip
> >>> sip.SIP_VERSION_STR
> '4.15.1' #this is the output
> http://stackoverflow.com/questions/3524168/how-do-i-get-a-python-modules-version-number-through-code
> On Tue, Aug 27, 2013 at 11:30 PM, aperi2007 <aperi2007 at gmail.com> wrote:
> > sorry, I have nt any python knowledgment.
> > How can I get the SIP version from python inside ?
> > On 28/08/2013 03:20, Saulteau Don wrote:
> >> There's been a bug filed at http://hub.qgis.org/issues/8507 that looks
> >> related.
> >> What version of SIP are you running? On arch linux, it fails with
> >> python2-sip v4.15.1 after sip was updated.
> >> On Tue, Aug 27, 2013 at 3:15 PM, Andrea Peri <aperi2007 at gmail.com>
> wrote:
> >>> Hi, try-ing to compile from last trunk on my RedHat server I'm have
> this
> >>> error:
> >>> sip: Deprecation warning:
> /usr/share/sip/PyQt4/QtCore/QtCoremod.sip:130:
> >>> %OptionalInclude is deprecated, use %Include and the 'optional'
> argument
> >>> instead
> >>> /usr/share/sip/PyQt4/QtCore/qabstractfileengine.sip:266: Annotations
> >>> should
> >>> not be used in explicit C/C++ signatures
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qfile.sip:138:
> >>> Annotations should not be used in explicit C/C++ signatures
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qobject.sip:237:
> >>> %GetCode should be used a sub-directive
> >>> /usr/share/sip/PyQt4/QtCore/qtextstream.sip:125:
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtCore/qtimer.sip:49:
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:33:
> >>> %Module version number should be specified using the 'version' argument
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/QtGuimod.sip:66:
> argument
> >>> instead
> >>> /usr/share/sip/PyQt4/QtGui/qapplication.sip:114:
> >>> %AccessCode should be used a sub-directive
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtGui/qshortcut.sip:42:
> >>> sip: Deprecation warning: /usr/share/sip/PyQt4/QtXml/QtXmlmod.sip:33:
> >>> /usr/share/sip/PyQt4/QtNetwork/QtNetworkmod.sip:33: %Module version
> >>> number
> >>> sip: QGraphicsEffect has not been defined
> >>> make[2]: *** [python/core/sipcorepart0.cpp] Error 1
> >>> make[1]: *** [python/CMakeFiles/python_module_qgis_core.dir/all] Error
> 2
> >>> make: *** [all] Error 2
> >>> Any thought ?
> >>> thx
> >>> Andrea Peri
> >>> qwerty àèìòù
> >>> _______________________________________________
> >>> Qgis-user mailing list
> >>> Qgis-user at lists.osgeo.org
> >>> http://lists.osgeo.org/mailman/listinfo/qgis-user
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130828/8092d601/attachment.html>
