[Qgis-user] Using the SDA4PP plugin with QGIS Lisboa
Lynkos
lynkosmail at gmail.com
Wed Aug 28 09:21:51 PDT 2013
After beating my head against the wall for a couple of days, I've managed
to get the SDA4PP plugin working with an old version of QGIS (1.4,
Enceladus). Still no luck though in the QGIS Lisboa I use normally. In
Lisboa, the plugin launches, but testing with the Components tool gives the
message: "Rpy2 (Python module) is missing. Please, install it.
Rpy2 could not call R-cran. Check Rpy2, R-cran and path definitions."
As it all works fine in Enceladus, all components are obviously installed
as they should be, but the plugin fails to find them. Is there an "easy"
way to resolve this without another two days of head beating?
As an alternative, I could continue using Enceladus just for the spatial
analysis, but whenever I switch between versions, I lose the toolbar
arrangement. Can the toolbars be blocked in place so this doesn't happen?
Thanks as ever for your collective help and support, Sarah.
*Sarah Gregg*
immagini - parole - territorio - natura
Web: www.wild-eyes.eu
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130828/8959abaf/attachment.html>
