[Qgis-user] OSX - QGIS not loading Grass plugin
William Kyngesburye
woklist at kyngchaos.com
Fri Aug 30 06:29:02 PDT 2013
QGIS needs a very specific version of GRASS. For my QGIS 1.8 you need GRASS 6.4.2, NOT the recent 6.4.3. You also need GDAL 1.9, NOT 1.10. Finally, you can move or rename GRASS.
On Aug 30, 2013, at 1:04 AM, Graeme Merrall wrote:
> I'm trying to get the Grass plugin to load in QGIS in OSX Mountain Lion.
> QGIS ver: 1.8.0 (kyngchaos)
> Grass ver: 6.4 (kyngchaos)
> GDAL ver: 1.10 (kyngchaos with Grass plugin)
> Python: 2.7.2
> The error I'm getting is:
> Failed to load /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so (Reason: Cannot load library /Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so: (dlopen(/Applications/QGIS.app/Contents/MacOS/../PlugIns/qgis/libgrassplugin.so, 5): Library not loaded: /Applications/GRASS-6.4.app/Contents/MacOS/lib/libgrass_gis.6.4.2.dylib
> Referenced from: /Applications/QGIS.app/Contents/PlugIns/qgis/libgrassplugin.so
> Reason: image not found))
> Following errors include libgrassprovider and libgrassrasterprovider.
> From from searching about I saw very old references to fftw install (tried, no joy) and tweaking your LD_LIBRARY_PATH. For LD_LIBRARY_PATH I exported both the QGIS plugins dir and Grass lib dir and started QGIS from the command line - still didn't work.
> Can anyone point out what's going wrong?
> Qgis-user mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
[Trillian] What are you supposed to do WITH a maniacally depressed robot?
[Marvin] You think you have problems? What are you supposed to do if you ARE a maniacally depressed robot? No, don't try and answer, I'm 50,000 times more intelligent than you and even I don't know the answer...
- HitchHiker's Guide to the Galaxy
