[Qgis-user] Four band raster displaying funny
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Mon Dec 2 09:11:47 PST 2013
Further testing indicates that the same (optimal) result can be had using a
combination of a vrt and gdal_translate without having to manually bother
with memory management.
dir /b /s *.tif > tiff_list.txt
> REM Builds a VRT. A VRT is basically just a XML file saying what all the
> source tif files are.
> gdalbuildvrt -input_file_list tiff_list.txt file.vrt
> REM This is what actually does the mosaicing.
> gdal_translate -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG
> -co JPEG_QUALITY=80 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co
> PHOTOMETRIC=YCBCR file.vrt file.tif
Relating to four bands, I can confirm the PHOTOMETRIC=RGB with JPEG
compression does leave the fourth band undefined:
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
> Band 2 Block=512x512 Type=Byte, ColorInterp=Green
> Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
> Band 4 Block=512x512 Type=Byte, ColorInterp=Undefined
The filesize is the same as setting no photometric flag. So that seems to
be the solution, at least where QGIS is concerned with 4 bands.
Thanks again,
Jonathan
On 2 December 2013 16:36, Andrew Harfoot <ajph at geodata.soton.ac.uk> wrote:
> Interesting!
> Just found that you can override the GDAL behaviour of adding alpha
> interpretation (this is the default as described in the GTiff format spec here
> <http://www.gdal.org/frmt_gtiff.html>) by adding the GDAL -co command
> PHOTOMETRIC=RGB. Not sure how this tallys with the YCBCR colour model used
> by JPEG though?
> Cheers,
> Andy
> On 02/12/2013 16:30, Jonathan Moules wrote:
> Hi Andy,
> I guess that makes sense.
> Relating to gdalwarp:
> - Output files by default are larger than gdal_merge.
> - But they can be much smaller. You have to set *both* -wm and --config
> GDAL_CACHEMAX - if you only set -wm, then the file is actually larger!
> - gdal_merge seems to do something that results in some heavy blurring
> when using -co PHOTOMETRIC=YCBCR - this doesn't happen with gdalwarp.
> So the optimal filesize for an aerial photograph is rendered with
> something like:
> gdalwarp -of GTiff -wm 9999 --config GDAL_CACHEMAX 9999 -co TILED=YES
>> -co BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=80 -co BLOCKXSIZE=512
>> -co BLOCKYSIZE=512 -co PHOTOMETRIC=YCBCR input1.tif input2.tif output.tif
> I've not tried the four-band stuff again; just trying to optimise by
> 3-band.
> Thanks,
> Jonathan
> On 2 December 2013 16:10, Andrew Harfoot <ajph at geodata.soton.ac.uk> wrote:
>> I think QGIS is innocent in this - if a band is set as an alpha channel
>> then it should be handled as such by default in a viewer (so mark down Arc
>> for not using the alpha information!).
>> GDAL is the culprit as it is adding the alpha interpretation without
>> being prompted. I have just replicated this with some RGBI imagery myself:
>> prior to passing through GDAL's hands the IR band is present, but isn't
>> interpreted as an alpha channel. I can't get the -setci switch to do
>> anything though :(
>> Cheers,
>> Andy
>> On 02/12/2013 16:00, Jonathan Moules wrote:
>> Hi Andy,
>> Yep, that was it. I didn't know QGIS could do that; another good example
>> of software trying to be "smart" and confusing the poor user. :-)
>> I didn't know gdalwarp could do mosaicing too. I'll have to test it.
>> I'll ask on the gdal list if I want to try the -setci parameter.
>> Many thanks!
>> Jonathan
>> On 2 December 2013 15:48, Andrew Harfoot <ajph at geodata.soton.ac.uk>wrote:
>>> PS. gdalwarp offers more flexibility when mosaicing rasters, and is
>>> better at memory management. I have just noticed that in GDAL 1.10 and
>>> above there is an gdalwarp option -setci that 'Sets the color
>>> interpretation of the bands of the target dataset from the source dataset'.
>>> This could be used to remove the assignment of the alpha channel to the IR
>>> band on merging. Sadly there isn't an example of its usage!
>>> Cheers,
>>> Andy
>>> On 02/12/2013 11:53, Jonathan Moules wrote:
>>> Hi List,
>>> I've got a 4 band raster aerial photography (RGBI) that comprises lots
>>> of tiles. I've merged some of the tiles together with:
>>> gdal_merge -o 1.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co
>>>> COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512
>>>> --optfile tiff_list.txt
>>> But the resultant file looks funny in QGIS.
>>> This is what the source file looks like (correct):
>>> [image: Inline images 1]
>>> This is what the merged file looks like (wrong):
>>> [image: Inline images 2]
>>> All the shadows are a whitey colour. This doesn't happen with 3-band
>>> (RGB) images.
>>> I've tried comparing individual bands; they all look different in the
>>> 4-band.
>>> However, if I open the four-band in ArcGIS, it looks fine (both source
>>> and original).
>>> Anyone know what's going on? Is it a QGIS bug or is it doing something
>>> "smart"; I can't see anything odd going on with symbology.
>>> Thanks,
>>> Jonathan
>>> This transmission is intended for the named addressee(s) only and may
>>> contain sensitive or protectively marked material up to RESTRICTED and
>>> should be handled accordingly. Unless you are the named addressee (or
>>> authorised to receive it for the addressee) you may not copy or use it, or
>>> disclose it to anyone else. If you have received this transmission in error
>>> please notify the sender immediately. All email traffic sent to or from us,
>>> including without limitation all GCSX traffic, may be subject to recording
>>> and/or monitoring in accordance with relevant legislation.
>>> Qgis-user mailing listQgis-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/qgis-user
>>> Andy Harfoot
>>> GeoData Institute
>>> University of Southampton
>>> Southampton
>>> SO17 1BJ
>>> Tel: +44 (0)23 8059 2719
>>> Fax: +44 (0)23 8059 2849
>>> www.geodata.soton.ac.uk
>> Andy Harfoot
>> GeoData Institute
>> Southampton
>> SO17 1BJ
> Andy Harfoot
> GeoData Institute
> Southampton
> SO17 1BJ
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131202/9768def7/attachment.html>
