[Qgis-user] MrSID raster and QGIS in linux
    Eric Goddard
    egoddard1010 at gmail.com
    Wed Dec  4 00:33:22 PST 2013
You will need to remove the --with-postgres=yes and
--with-postgres-includes=/usr/include/postgresql options. As for the
lex error, you should be able to fix that by running
sudo apt-get install flex
on the command line before configuring.
On Wed, Dec 4, 2013 at 1:42 AM, Glenn Hunt <hunt.glenn at gmail.com> wrote:
> Hi Eric,
> I decided not to compile postgis but do I then need to change the configure
> line for compiling grass 64? I just tried to compile now using the full text
> in your document and got an error right at the beginning.
> checing for lex... no
> configure: error: *** Unable to locate lex.
> On 04/12/13 00:20, Eric Goddard wrote:
> The packages I use for postgres on Ubuntu 13.04 are:
> postgresql-server-dev-9.1 postgresql-client postgresql-9.1
> postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
> it may still be on 9. Try finding the equivalent packages with
> synaptic, or simply don't compile postgis if you never use it.
> On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <hunt.glenn at gmail.com> wrote:
> Re configured, make, and make installed gdal. Moved onto the postgis
> Downloaded package but when in tried to configure i got an error
> checking for pg_config... no
> configure: error: could not find pg_config within the current path. You may
> need to try re-running configure with a --with-pgconfig parameter.
> make: *** [GNUmakefile] Error 1
> ideas?
> On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
> I would recompile gdal. Switch to the gdal source directory and run
> 'make clean', and then re run the ./configure, make, and make install
> lines.
> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
> After posting that I went into synaptic and installed geotiff 1.4.
> Following
> that it seems it worked.
> Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
> are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
> I did manage to get the gdal compiled without geotiff, but I'm not sure
> there may have been some errors that I just overlooked. Would you
> recommend
> starting from the beginning again, or just keep going as is?
> Regards,
> BB
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> Qgis-user mailing list
> [hidden email]
> [hidden email]
> ________________________________
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
> To unsubscribe from MrSID raster and QGIS in linux, click here.
> NAML
> View this message in context: Re: MrSID raster and QGIS in linux
