[Qgis-user] MrSID raster and QGIS in linux
BigBaka hunt.glenn at gmail.com
Wed Dec 4 01:04:35 PST 2013
Hi Eric,
Am I missing some compiling package? I also had to download a program
called bison. Now I getting an error Unable to locate curses. Also
couldn't seem to locate W11 and X. When I tried to install a package
called curses.h it said something about "package ncurses-hexedit should
be rebuilt with new debhelper to get trigger support! - whatever that means.
On 04/12/13 15:34, Eric Goddard [via OSGeo.org] wrote:
> You will need to remove the --with-postgres=yes and
> --with-postgres-includes=/usr/include/postgresql options. As for the
> lex error, you should be able to fix that by running
> sudo apt-get install flex
> on the command line before configuring.
> On Wed, Dec 4, 2013 at 1:42 AM, Glenn Hunt <[hidden email]
> </user/SendEmail.jtp?type=node&node=5092585&i=0>> wrote:
> > Hi Eric,
> > I decided not to compile postgis but do I then need to change the
> configure
> > line for compiling grass 64? I just tried to compile now using the
> full text
> > in your document and got an error right at the beginning.
> > checing for lex... no
> > configure: error: *** Unable to locate lex.
> > On 04/12/13 00:20, Eric Goddard wrote:
> > The packages I use for postgres on Ubuntu 13.04 are:
> > postgresql-server-dev-9.1 postgresql-client postgresql-9.1
> > postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
> > it may still be on 9. Try finding the equivalent packages with
> > synaptic, or simply don't compile postgis if you never use it.
> > On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <[hidden email]
> </user/SendEmail.jtp?type=node&node=5092585&i=1>> wrote:
> > Re configured, make, and make installed gdal. Moved onto the postgis
> > Downloaded package but when in tried to configure i got an error
> > checking for pg_config... no
> > configure: error: could not find pg_config within the current path.
> You may
> > need to try re-running configure with a --with-pgconfig parameter.
> > make: *** [GNUmakefile] Error 1
> > ideas?
> > On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
> > I would recompile gdal. Switch to the gdal source directory and run
> > 'make clean', and then re run the ./configure, make, and make install
> > lines.
> > On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
> > After posting that I went into synaptic and installed geotiff 1.4.
> > Following
> > that it seems it worked.
> > Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
> > are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
> > I did manage to get the gdal compiled without geotiff, but I'm not sure
> > there may have been some errors that I just overlooked. Would you
> > recommend
> > starting from the beginning again, or just keep going as is?
> > Regards,
> > BB
> > View this message in context:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
> > Sent from the Quantum GIS - User mailing list archive at Nabble.com.
> > Qgis-user mailing list
> > [hidden email]
> > http://lists.osgeo.org/mailman/listinfo/qgis-user
> > [hidden email]
> > If you reply to this email, your message will be added to the
> discussion
> > below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
> > To unsubscribe from MrSID raster and QGIS in linux, click here.
> > NAML
> > View this message in context: Re: MrSID raster and QGIS in linux
> > [hidden email] </user/SendEmail.jtp?type=node&node=5092585&i=2>
> [hidden email] </user/SendEmail.jtp?type=node&node=5092585&i=3>
> discussion below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092585.html
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5090885&code=aHVudC5nbGVubkBnbWFpbC5jb218NTA5MDg4NXwtMjA4MDk5NDE3MA==>.
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092595.html
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131204/60bf149d/attachment.html>
