[Qgis-user] MrSID raster and QGIS in linux
Eric Goddard
egoddard1010 at gmail.com
Wed Dec 4 01:14:27 PST 2013
It sounds like you didn't get all of the packages in the dependencies
section installed; many of the development packages should have been
installed with the build-essential package. bison and ncurses-dev are
also in the list and will take care of the curses error., and the
libxmu-dev package will fix the X error. Did you paste the whole chunk
of dependencies in as a single line?
On Wed, Dec 4, 2013 at 3:04 AM, BigBaka <hunt.glenn at gmail.com> wrote:
> Hi Eric,
> Am I missing some compiling package? I also had to download a program called
> bison. Now I getting an error Unable to locate curses. Also couldn't seem to
> locate W11 and X. When I tried to install a package called curses.h it said
> something about "package ncurses-hexedit should be rebuilt with new
> debhelper to get trigger support! - whatever that means.
> On 04/12/13 15:34, Eric Goddard [via OSGeo.org] wrote:
> You will need to remove the --with-postgres=yes and
> --with-postgres-includes=/usr/include/postgresql options. As for the
> lex error, you should be able to fix that by running
> sudo apt-get install flex
> on the command line before configuring.
> On Wed, Dec 4, 2013 at 1:42 AM, Glenn Hunt <[hidden email]> wrote:
>> Hi Eric,
>> I decided not to compile postgis but do I then need to change the
>> configure
>> line for compiling grass 64? I just tried to compile now using the full
>> text
>> in your document and got an error right at the beginning.
>> checing for lex... no
>> configure: error: *** Unable to locate lex.
>> On 04/12/13 00:20, Eric Goddard wrote:
>> The packages I use for postgres on Ubuntu 13.04 are:
>> postgresql-server-dev-9.1 postgresql-client postgresql-9.1
>> postgresql-contrib-9.1. I don't know if Ubuntu 12.04 has postgres 9.1;
>> it may still be on 9. Try finding the equivalent packages with
>> synaptic, or simply don't compile postgis if you never use it.
>> On Tue, Dec 3, 2013 at 11:07 AM, BigBaka <[hidden email]> wrote:
>> Re configured, make, and make installed gdal. Moved onto the postgis
>> Downloaded package but when in tried to configure i got an error
>> checking for pg_config... no
>> configure: error: could not find pg_config within the current path. You
>> may
>> need to try re-running configure with a --with-pgconfig parameter.
>> make: *** [GNUmakefile] Error 1
>> ideas?
>> On 03/12/13 23:26, Eric Goddard [via OSGeo.org] wrote:
>> I would recompile gdal. Switch to the gdal source directory and run
>> 'make clean', and then re run the ./configure, make, and make install
>> lines.
>> On Tue, Dec 3, 2013 at 10:21 AM, BigBaka <[hidden email]> wrote:
>> After posting that I went into synaptic and installed geotiff 1.4.
>> Following
>> that it seems it worked.
>> Values for GEOTIFF_INCLUDE_DIR and GEOTIFF_LIBRARY
>> are usr/include/geotiff and usr/lib/libgeotiff.so respectively now.
>> I did manage to get the gdal compiled without geotiff, but I'm not sure
>> there may have been some errors that I just overlooked. Would you
>> recommend
>> starting from the beginning again, or just keep going as is?
>> Regards,
>> BB
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092439.html
>> Sent from the Quantum GIS - User mailing list archive at Nabble.com.
>> Qgis-user mailing list
>> [hidden email]
>> http://lists.osgeo.org/mailman/listinfo/qgis-user
>> [hidden email]
>> If you reply to this email, your message will be added to the discussion
>> below:
>> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092441.html
>> To unsubscribe from MrSID raster and QGIS in linux, click here.
>> NAML
>> View this message in context: Re: MrSID raster and QGIS in linux
>> [hidden email]
> [hidden email]
> below:
> http://osgeo-org.1560.x6.nabble.com/MrSID-raster-and-QGIS-in-linux-tp5090885p5092585.html
> NAML
