[Qgis-user] PostGIS Import Error: addgeometrycolumn()
Steffen G
martsystems at gmx.net
Fri Dec 6 00:11:35 PST 2013
I use QGIS 2.0 and on the backend PostgreSQL 9.3 with PostGIS 2.0.
If I try to import some polygons with:
- DB-Manager or
- PostGIS Shapefile Import/Export Manager
I received the message:
Failed in pgui_exec(): FEHLER: Function addgeometrycolumn(unknown, unknown,
unknown, unknown, unknown, integer) is not unique
LINE 53: SELECT AddGeometryColumn('public','foo','geom','0','MULTI...
HINT: Could not choose a best candidate function. You may need to add
explicit
type casts.
A look in the PostGIS function lib shows 6 different AddGeometryColumn()
Functions but none works (I renamed one by one to have a unique function)
Any ideas?
View this message in context: http://osgeo-org.1560.x6.nabble.com/PostGIS-Import-Error-addgeometrycolumn-tp5093059.html
Sent from the Quantum GIS - User mailing list archive at Nabble.com.
