[Qgis-user] 3D dxf files
Siki Zoltan siki at agt.bme.hu
Mon Dec 9 23:02:17 PST 2013
Dear Matt,
which version did you try?
What type of entites your dxf file(s) contains? Are them supported by ogr
DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
Try to check entities with ogrinfo.
I had trouble with 1.8 (exspecially on Windows) to load dxf.
I used ogr2ogr instead QGIS, because you can set more options.
I cannot find any DXf file in the zip file you specify.
Best regards,
Zoltan
On Tue, 10 Dec 2013, Matt Boyd wrote:
> Hi group,
> I'm trying to make sense of some DXF files.
> these ones in particular
> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_models/3D_model_attributes.zip
> there's also a 3D pdf model here..
> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_models/t009_OtwayBasin_3D.pdf
> QGIS isn't able to open the dxf files, or it does but all I see is an icon
> called "entities" with no attributes. Ideally I'd be able to load these as
> rasters and make a few maps.
> Any ideas?
> thanks
> matt
