[Qgis-user] 3D dxf files
Matt Boyd
mattslists at gmail.com
Tue Dec 10 14:58:57 PST 2013
I'll give ogr2ogr a shot.
woops, sorry wrong link I meant this one
http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_models/t009_OtwayBasin_3D_dxf.zip
On Tue, Dec 10, 2013 at 6:02 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
> Dear Matt,
> which version did you try?
> What type of entites your dxf file(s) contains? Are them supported by ogr
> DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
> Try to check entities with ogrinfo.
> I had trouble with 1.8 (exspecially on Windows) to load dxf.
> I used ogr2ogr instead QGIS, because you can set more options.
> I cannot find any DXf file in the zip file you specify.
> Best regards,
> Zoltan
> On Tue, 10 Dec 2013, Matt Boyd wrote:
> Hi group,
>> I'm trying to make sense of some DXF files.
>> these ones in particular
>> models/3D_model_attributes.zip
>> there's also a 3D pdf model here..
>> models/t009_OtwayBasin_3D.pdf
>> QGIS isn't able to open the dxf files, or it does but all I see is an icon
>> called "entities" with no attributes. Ideally I'd be able to load these as
>> rasters and make a few maps.
>> Any ideas?
>> thanks
>> matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131211/334f4c63/attachment.html>
