[Qgis-user] 3D dxf files
Siki Zoltan
siki at agt.bme.hu
Wed Dec 11 13:59:34 PST 2013
Dear Matt,
I've tested your dxf files in QGIS 2.0
Otway_Basin_curves.dxf loaded successfully (2D polylines)
Otway_Basin_Faults-basin.dxf not loaded, 3D faces are not suported by GDAL
DXF driver
Otway_Basin_Faults-shallow.dxf not loaded 3D faces
Otway_Basin_Granites-magnetics.dxf not loaded 3D faces
Otway_Basin_Granites-gravity.dxf not loaded 3D faces
You should find another way to import 3D faces from a dxf file.
Regards,
Zoltan
On Wed, 11 Dec 2013, Matt Boyd wrote:
> I'll give ogr2ogr a shot.
> woops, sorry wrong link I meant this one
> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_models/t009_OtwayBasin_3D_dxf.zip
> On Tue, Dec 10, 2013 at 6:02 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
>> Dear Matt,
>> which version did you try?
>> What type of entites your dxf file(s) contains? Are them supported by ogr
>> DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
>> Try to check entities with ogrinfo.
>> I had trouble with 1.8 (exspecially on Windows) to load dxf.
>> I used ogr2ogr instead QGIS, because you can set more options.
>> I cannot find any DXf file in the zip file you specify.
>> Best regards,
>> Zoltan
>> On Tue, 10 Dec 2013, Matt Boyd wrote:
>> Hi group,
>>> I'm trying to make sense of some DXF files.
>>> these ones in particular
>>> models/3D_model_attributes.zip
>>> there's also a 3D pdf model here..
>>> models/t009_OtwayBasin_3D.pdf
>>> QGIS isn't able to open the dxf files, or it does but all I see is an icon
>>> called "entities" with no attributes. Ideally I'd be able to load these as
>>> rasters and make a few maps.
>>> Any ideas?
>>> thanks
>>> matt
