[Qgis-user] 3D dxf files
    Matt Boyd
    mattslists at gmail.com
    Wed Dec 11 14:03:43 PST 2013
Thanks Zoltan,
I'll keep hunting.
Regards
Matt
On Thu, Dec 12, 2013 at 8:59 AM, Siki Zoltan <siki at agt.bme.hu> wrote:
> Dear Matt,
> I've tested your dxf files in QGIS 2.0
> Otway_Basin_curves.dxf loaded successfully (2D polylines)
> Otway_Basin_Faults-basin.dxf not loaded, 3D faces are not suported by GDAL
> DXF driver
> Otway_Basin_Faults-shallow.dxf not loaded 3D faces
> Otway_Basin_Granites-magnetics.dxf not loaded 3D faces
> Otway_Basin_Granites-gravity.dxf not loaded 3D faces
> You should find another way to import 3D faces from a dxf file.
> Regards,
> Zoltan
> On Wed, 11 Dec 2013, Matt Boyd wrote:
>  I'll give ogr2ogr a shot.
>> woops, sorry wrong link I meant this one
>> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_
>> models/t009_OtwayBasin_3D_dxf.zip
>> On Tue, Dec 10, 2013 at 6:02 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
>>  Dear Matt,
>>> which version did you try?
>>> What type of entites your dxf file(s) contains? Are them supported by ogr
>>> DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
>>> Try to check entities with ogrinfo.
>>> I had trouble with 1.8 (exspecially on Windows) to load dxf.
>>> I used ogr2ogr instead QGIS, because you can set more options.
>>> I cannot find any DXf file in the zip file you specify.
>>> Best regards,
>>> Zoltan
>>> On Tue, 10 Dec 2013, Matt Boyd wrote:
>>>  Hi group,
>>>> I'm trying to make sense of some DXF files.
>>>> these ones in particular
>>>> models/3D_model_attributes.zip
>>>> there's also a 3D pdf model here..
>>>> models/t009_OtwayBasin_3D.pdf
>>>> QGIS isn't able to open the dxf files, or it does but all I see is an
>>>> icon
>>>> called "entities" with no attributes. Ideally I'd be able to load these
>>>> as
>>>> rasters and make a few maps.
>>>> Any ideas?
>>>> thanks
>>>> matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131212/b22964da/attachment.html>
