[Qgis-user] WMS layer not working in QGIS
Richard Duivenvoorde
rdmailings at duif.net
Tue Dec 10 13:16:32 PST 2013
On 10-12-13 18:58, Jonathan Moules wrote:
> Hi List,
> Before I report this one as a bug I want to see if it's just me.
> I'm trying to access the WMS layer from the UK Land registry here:
> http://inspire.landregistry.gov.uk/inspire/ows
> (note: It only shows when zoomed in closer than 15k.)
> This works fine in ArcMap and an OpenLayers client but doesn't in QGIS.
> Once I've added the layer (the GetCapabilities is fine) my error log says:
> Map request error (Status: 200; Response: �PNG
> ; Content-Type: ;
> URL:http://uatinspire.landregistry.gov.uk/u1c/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=433672.13541449012700468,361044.86458240094361827,437939.86458550987299532,362873.13541759905638173&CRS=EPSG:27700&WIDTH=1613&HEIGHT=691&LAYERS=inspire:CP.CadastralParcel&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE)
Hi Jonathan,
using it in qgis results in this url:
http://uatinspire.landregistry.gov.uk/u1c/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=-9.49699999999999989,49.76700000000000301,2.80900000000000016,61.57900000000000063&CRS=CRS:84&WIDTH=497&HEIGHT=478&LAYERS=inspire:CP.CadastralParcel&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE
both your url and the url above end up with this result with me in the
browser:
<SOAP-ENV:Envelope><SOAP-ENV:Body><SOAP-ENV:Fault><faultcode>SOAP-ENV:Server</faultcode><faultstring>A
timeout occurred during
processing</faultstring><faultactor>/ows</faultactor><detail><text>Timeout.
Broker U1C2BRK did not provide a response within the specified time
interval (57
seconds)</text></detail></SOAP-ENV:Fault></SOAP-ENV:Body></SOAP-ENV:Envelope>
Are you maybe allowed to do/see things which QGIS/I do am not allowed? A
proxy config maybe?
Regards,
