[Qgis-user] WMS layer not working in QGIS
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Wed Dec 11 01:33:32 PST 2013
Jonathan Moules <jonathanmoules at ...> writes:
> Hi List,
> Before I report this one as a bug I want to see if it's just me.
> I'm trying to access the WMS layer from the UK Land registry here:
> http://inspire.landregistry.gov.uk/inspire/ows
> (note: It only shows when zoomed in closer than 15k.)
> This works fine in ArcMap and an OpenLayers client but doesn't in QGIS.
Once I've added the layer (the GetCapabilities is fine) my error log says:
> Map request error (Status: 200; Response: �PNG; Content-Type: ;
URL:http://uatinspire.landregistry.gov.uk/u1c/ows?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&BBOX=433672.13541449012700468,361044.86458240094361827,437939.86458550987299532,362873.13541759905638173&CRS=EPSG:27700&WIDTH=1613&HEIGHT=691&LAYERS=inspire:CP.CadastralParcel&STYLES=&FORMAT=image/png&DPI=96&MAP_RESOLUTION=96&FORMAT_OPTIONS=dpi:96&TRANSPARENT=TRUE)
> But that URL works just fine in a web-browser.
> Does it work for anyone else? I've tried both 2.0 and the latest weekly.
> Cheers,
> Jonathan
This service works also with OpenJUMP. However, you must not use the
advertised GetMap URL but the same base URL that is used for
GetCapabilities. But it does not help to check the corresponding box in QGIS
settings.
I checked that service is sending valid image data back to QGIS but for some
reason QGIS throws an error. Perhaps it does not like the response headers?
Is it awaiting for content type, which seems to miss. QGIS gives the same
error with text "Response: �PNG;" even if I use &format=image/jpeg in
request and then server is also sending back a jpeg image. Here is the
beginning of the raw data that comes from the server.
HTTP/1.0 200 OK
Date: Wed, 11 Dec 2013 09:19:30 GMT
p3p: CP="NON CUR OTPi OUR NOR UNI"
X-CFLO-Cache-Result: TCP_NC_MISS
Content-Length: 69585
X-Cache: MISS from our.cache.fi
Proxy-Connection: keep-alive
Image data begins
-Jukka Rahkonen-
