[Qgis-user] Menu Customisation
Jonathan Moules
jonathanmoules at warwickshire.gov.uk
Wed Dec 11 06:13:36 PST 2013
Hi Thomas,
I've discovered that one is removable separately as it is a plugin. Same
with the SQL Anywhere one.
But the other ones aren't disappearing correctly either. I.e. the postgis
elephant (although that one does stay turned off when I restart QGIS) or
WCS etc. So none of them are working for me. :-S
Also looking at it, I note that there are many more items on the
customisation menu than there are on the menu itself. I.e. "properties" and
"save as".
Is that because it's shared with the layers panel as well?
Thanks,
Jonathan
On 11 December 2013 14:07, Thomas Colley
<t.colley at neath-porttalbot.gov.uk>wrote:
> Hi Jonathan
> It seems to be Oracle Raster in particular that can’t be removed. Other
> entries in the mLayerMenu work fine for me (restart needed).
> Is that the same for you?
> Cheers
> Tom
> *From:* qgis-user-bounces at lists.osgeo.org [mailto:
> qgis-user-bounces at lists.osgeo.org] *On Behalf Of *Jonathan Moules
> *Sent:* 11 December 2013 11:45
> *To:* qgis-user at lists.osgeo.org
> *Subject:* [Qgis-user] Menu Customisation
> Hi List,
> Does menu customisation work? As in Settings-> Customisation?
> I've tried several times now to customise menus (i.e., by removing the
> Oracle Raster from the "mLayerMenu"), but nothing happens. So I try
> restarting QGIS, but then the next time it opens the item is checked again.
> Am I doing something wrong?
> Also, where are these changes saved? The registry (this is Windows)?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131211/97844e6e/attachment.html>
