[Qgis-user] Menu Customisation
Thomas Colley
t.colley at neath-porttalbot.gov.uk
Wed Dec 11 06:46:27 PST 2013
On 2.0.1 all of those entries (properties, save as etc) are in the
layers menu. http://s8.postimg.org/3nlf392d1/layer_menu.gif
Are you using an older version?
Cheers
Tom
From: Jonathan Moules [mailto:jonathanmoules at warwickshire.gov.uk]
Sent: 11 December 2013 14:14
To: Thomas Colley
Cc: qgis-user at lists.osgeo.org
Subject: Re: [Qgis-user] Menu Customisation
Hi Thomas,
I've discovered that one is removable separately as it is a plugin. Same
with the SQL Anywhere one.
But the other ones aren't disappearing correctly either. I.e. the
postgis elephant (although that one does stay turned off when I restart
QGIS) or WCS etc. So none of them are working for me. :-S
Also looking at it, I note that there are many more items on the
customisation menu than there are on the menu itself. I.e. "properties"
and "save as".
Is that because it's shared with the layers panel as well?
Thanks,
Jonathan
On 11 December 2013 14:07, Thomas Colley
<t.colley at neath-porttalbot.gov.uk> wrote:
Hi Jonathan
It seems to be Oracle Raster in particular that can't be removed. Other
entries in the mLayerMenu work fine for me (restart needed).
Is that the same for you?
Cheers
Tom
[mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
Sent: 11 December 2013 11:45
To: qgis-user at lists.osgeo.org
Subject: [Qgis-user] Menu Customisation
Hi List,
Does menu customisation work? As in Settings-> Customisation?
I've tried several times now to customise menus (i.e., by removing the
Oracle Raster from the "mLayerMenu"), but nothing happens. So I try
restarting QGIS, but then the next time it opens the item is checked
again.
Am I doing something wrong?
Also, where are these changes saved? The registry (this is Windows)?
Thanks,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it,
or disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject
to recording and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131211/936bf1fb/attachment.html>
