[Qgis-user] Menu Customisation
Radim Blazek
radim.blazek at gmail.com
Wed Dec 11 07:00:47 PST 2013
On Wed, Dec 11, 2013 at 3:07 PM, Thomas Colley
<t.colley at neath-porttalbot.gov.uk> wrote:
> Hi Jonathan
> It seems to be Oracle Raster in particular that can’t be removed. Other
> entries in the mLayerMenu work fine for me (restart needed).
That's because mQActionPointer in QgsOraclePlugin does not have
objectName. Some (many) plugins do not set objectName on QMenu and
QAction and thus cannot be customized. If there is objectName missing
in tree path to an item, it cannot be customized.
It was recently discussed
http://lists.osgeo.org/pipermail/qgis-developer/2013-November/029545.html
and there is this issue
http://hub.qgis.org/issues/9134
Radim
> Is that the same for you?
> Cheers
> Tom
> From: qgis-user-bounces at lists.osgeo.org
> [mailto:qgis-user-bounces at lists.osgeo.org] On Behalf Of Jonathan Moules
> Sent: 11 December 2013 11:45
> To: qgis-user at lists.osgeo.org
> Subject: [Qgis-user] Menu Customisation
> Hi List,
> Does menu customisation work? As in Settings-> Customisation?
> I've tried several times now to customise menus (i.e., by removing the
> Oracle Raster from the "mLayerMenu"), but nothing happens. So I try
> restarting QGIS, but then the next time it opens the item is checked again.
> Am I doing something wrong?
> Also, where are these changes saved? The registry (this is Windows)?
> Thanks,
> Jonathan
> This transmission is intended for the named addressee(s) only and may
> contain sensitive or protectively marked material up to RESTRICTED and
> should be handled accordingly. Unless you are the named addressee (or
> authorised to receive it for the addressee) you may not copy or use it, or
> disclose it to anyone else. If you have received this transmission in error
> please notify the sender immediately. All email traffic sent to or from us,
> including without limitation all GCSX traffic, may be subject to recording
> and/or monitoring in accordance with relevant legislation.
> Qgis-user mailing list
