[Qgis-user] Fwd: adding a CSV delimited text layer
Chris Crook
ccrook at linz.govt.nz
Thu Dec 12 21:48:56 PST 2013
Interesting ... One other option in 2.0 is that you can select the file encoding. It is UTF8 initially (actually the default is whatever you used last for a file of the same extension), so you may be able to load your Mac files by selecting a different encoding.
Glad you've got it sorted
Cheers
Chris
________________________________________
Sent: 13 December 2013 17:01
To: Michael Goldstein
Cc: Joshua Brooks; qgis-user at lists.osgeo.org; Chris Crook
Subject: Re: [Qgis-user] Fwd: adding a CSV delimited text layer
I used open office and everything sorted itself out.
Thanks for all the help
On 2013-12-12, at 6:32 PM, Michael Goldstein <michael.goldstein7 at gmail.com<mailto:michael.goldstein7 at gmail.com>> wrote:
I've had confusing CSV incompatibility issues as a Mac user (though not with GQIS). Turns out that Mac Excel does not code the files in UTF-8, and that chokes some applications.
One quick fix was to load the file into Text Wrangler and save it specifying UTF-8 as the character coding. Another, is to use Open Office calc, which also lets you control character coding.
This may not be the problem, but when I saw that the user was on a Mac, it came to mind.
Michael
On Dec 12, 2013, at 5:31 PM, Joshua Brooks wrote:
Interesting. Chris sent me a copy, Linux with 2.0.1 was happy to use it as it was. There were extra unnamed and blank cols and line endings were CR.
On Dec 13, 2013 3:02 AM, "Chris Crook" <ccrook at linz.govt.nz<mailto:ccrook at linz.govt.nz>> wrote:
Qgis-user mailing list
Qgis-user at lists.osgeo.org<mailto:Qgis-user at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/qgis-user
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
