[Qgis-user] Problems to kriging
    JosĂ© Carlos Guerrero AntĂșnez
    jcgantunez at gmail.com
    Fri Dec 13 12:16:26 PST 2013
I want to kriging a vectorial point from SAGA 2.1, geoalgorithm "Kriging"
and can't do it, and I'm working with OSX 10.6.8 and QGIS 2.0.1.
This error message is obtained:
Oooops! The following output layers could not be open
   - Grid: /..../Datos_Variables-2013/humedad_grid.tif
   - Variance: /..../Datos_Variables-2013/humedad_variance.tif
The above files could not be opened, which probably indicates that they
were not correctly produced by the executed algorithm
Checking the log information might help you see why those layers were not
created as expected
This algorithm requires SAGA to be run. A test to check if SAGA is
correctly installed and configured in your system has been performed, with
the following result:
SAGA seems to be correctly installed and configured
Best regards,
Jose Carlos Guerrero
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131213/1f81a79a/attachment.html>
