[Qgis-user] 3D dxf files
    Matt Boyd
    mattslists at gmail.com
    Sun Dec 15 16:04:59 PST 2013
Hi Zoltan,
the script looks fine to me however, all I get in the output is
id;layer;wkt
any thoughts on what I'm not seeing?
Thanks
On Mon, Dec 16, 2013 at 10:19 AM, Matt Boyd <mattslists at gmail.com> wrote:
> Wow,
> thanks Zoltan, I just saw this email this morning and this is exactly what
> I was thinking I'd have to do myself.
> I did manage to get SAGA to load the dxf, however I'd only made it as far
> as being able to apply a value to each polygon, not each node.
> I'll get onto this now.
> Many thanks and much appreciation.
> Matt
> On Fri, Dec 13, 2013 at 6:57 AM, Siki Zoltan <siki at agt.bme.hu> wrote:
>> Dear Matt,
>> I've written an awk script to convert 3DFACE-s form dxf to a delimited
>> text file. Please find attached.
>> If you use Linux, start it in the shell like:
>> gawk -f 3dface2csv.awk Otway_Basin_Granites-gravity.dxf > result.csv
>> You can load the result.csv into QGIS az a delimited text layer with WKT
>> column.
>> Regards,
>> Zoltan
>> On Wed, 11 Dec 2013, Siki Zoltan wrote:
>>  Dear Matt,
>>> I've tested your dxf files in QGIS 2.0
>>> Otway_Basin_curves.dxf loaded successfully (2D polylines)
>>> Otway_Basin_Faults-basin.dxf not loaded, 3D faces are not suported by
>>> GDAL DXF driver
>>> Otway_Basin_Faults-shallow.dxf not loaded 3D faces
>>> Otway_Basin_Granites-magnetics.dxf not loaded 3D faces
>>> Otway_Basin_Granites-gravity.dxf not loaded 3D faces
>>> You should find another way to import 3D faces from a dxf file.
>>> Regards,
>>> Zoltan
>>> On Wed, 11 Dec 2013, Matt Boyd wrote:
>>>  I'll give ogr2ogr a shot.
>>>> woops, sorry wrong link I meant this one
>>>> http://er-info.dpi.vic.gov.au/cgi-bin/download.pl?ID=3D_
>>>> models/t009_OtwayBasin_3D_dxf.zip
>>>> On Tue, Dec 10, 2013 at 6:02 PM, Siki Zoltan <siki at agt.bme.hu> wrote:
>>>>  Dear Matt,
>>>>> which version did you try?
>>>>> What type of entites your dxf file(s) contains? Are them supported by
>>>>> ogr
>>>>> DXF driver? Check http://www.gdal.org/ogr/drv_dxf.html
>>>>> Try to check entities with ogrinfo.
>>>>> I had trouble with 1.8 (exspecially on Windows) to load dxf.
>>>>> I used ogr2ogr instead QGIS, because you can set more options.
>>>>> I cannot find any DXf file in the zip file you specify.
>>>>> Best regards,
>>>>> Zoltan
>>>>> On Tue, 10 Dec 2013, Matt Boyd wrote:
>>>>>  Hi group,
>>>>>> I'm trying to make sense of some DXF files.
>>>>>> these ones in particular
>>>>>> models/3D_model_attributes.zip
>>>>>> there's also a 3D pdf model here..
>>>>>> models/t009_OtwayBasin_3D.pdf
>>>>>> QGIS isn't able to open the dxf files, or it does but all I see is an
>>>>>> icon
>>>>>> called "entities" with no attributes. Ideally I'd be able to load
>>>>>> these as
>>>>>> rasters and make a few maps.
>>>>>> Any ideas?
>>>>>> thanks
>>>>>> matt
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131216/acdd3fd5/attachment.html>
