[Qgis-user] Weekly builds and JP2 files
Andre Joost
andre+joost at nurfuerspam.de
Wed Dec 18 07:35:55 PST 2013
Am 17.12.2013 20:47, schrieb Jukka Rahkonen:
> If there are several drivers for JPEG2000 GDAL is using the first on the
> list. You can skip a driver by setting GDAL_SKIP environment. Thus, if I
> would like to have a try with JP2OpenJPEG I should run SET GDAL_SKIP=JP2ECW
> first. No idea really how and where I should do it so that QGIS starts with
> that setting.
From the menue, Settings -> Options, GDAL tab, lets you select or
deselect every driver. QGIS 2.0.1 32bit standalone has JP2ECW and
JP2Open, while OSGEO4W QGIS-dev only has the second one, unless you
loaded the ecw package separately.
Greetings,
André Joost
