[Qgis-user] Weekly builds and JP2 files
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Thu Dec 19 07:16:05 PST 2013
I'm wondering - is there a reason that the JP2Open is distributed with
QGIS/GDAL given it seems to do a terrible job? At least it does with all
the ones I've tested against. Could the JP2ECW be distributed as the
default instead?
(again, I'm using the weekly build here).
Cheers,
Jonathan
On 18 December 2013 15:35, Andre Joost <andre+joost at nurfuerspam.de> wrote:
> Am 17.12.2013 20:47, schrieb Jukka Rahkonen:
>> If there are several drivers for JPEG2000 GDAL is using the first on the
>> list. You can skip a driver by setting GDAL_SKIP environment. Thus, if I
>> would like to have a try with JP2OpenJPEG I should run SET
>> GDAL_SKIP=JP2ECW
>> first. No idea really how and where I should do it so that QGIS starts
>> with
>> that setting.
> From the menue, Settings -> Options, GDAL tab, lets you select or deselect
> every driver. QGIS 2.0.1 32bit standalone has JP2ECW and JP2Open, while
> OSGEO4W QGIS-dev only has the second one, unless you loaded the ecw package
> separately.
> Greetings,
> André Joost
> Qgis-user mailing list
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20131219/3b4b7136/attachment.html>
