[Qgis-user] QGIS Server on CentOS 6
Bo Gusman
bo at bogusville.us
Mon Feb 4 17:16:44 PST 2013
Hi Andreas.
I have just met with some success for the first time and document here
what I found, for any others who may encounter the same.
As I described previously, I used the URL from the QGIS Server tutorial
page which is
http://localhost/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
This returns an error, Premature end of script headers.
You corrected me with the following:
http://localhost/cgi-bin/qgis_mapserv.fcgi?map=/path/to/your/qgis-projects/project.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetCapabilities
This now returns me an XML document that appears to describe my test
map. Huzzah!
I'm now ready to start learning something more about GIS! Thank you for
your help!
Bo
On 2/3/2013 11:26 AM, Andreas Neumann wrote:
> Hi,
> Here are the two resources I reccommend:
> http://hub.qgis.org/projects/quantum-gis/wiki/QGIS_Server_Tutorial
> for the server
> and
> https://github.com/qgis/qgis-web-client
> the README part
> for the installation of the client.
> In addition, please review the steps I outlined in my last email, esp.
> the part about using GetCapabilities vs. GetProjectSettings.
> I would first start testing QGIS server, as I said, first manually,
> and then with QGIS desktop as a client.
> In this request you mention below:
> you are missing the "map" parameter
> e.g.
> If your .qgs project file would reside at
> Hope this helps as a start,
> Andreas
> On 2/3/13 7:15 PM, Bo Gusman wrote:
>> Hi Andreas. Thanks for your reply. I'll answer your questions as best
>> as I can.
>> First of all, I've relied heavily on Google as it is most always true
>> that someone has the same problems as I do. This hasn't quite worked
>> out this time, though.
>> > Can you tell us what documentation you worked with?
>> Installation was based on the following:
>> http://hub.qgis.org/projects/quantum-gis/wiki/Download#21-Debian
>> As I mentioned, I tried installing on Debian (actually TurnkeyLinux a
>> Debian clone that I use quite extensively in other contexts). After
>> configuring the appropriate repositories, the software itself
>> installed without error, but the following threw a "Premature end of
>> script headers" error:
>> I would expect that s/w installed from the repos would "just work".
>> Sadly, this most basic test didn't.
>> I decided to try an install on CentOS 6 as I'm most familiar with
>> that (more years of tearing my hair out, as it were.) Once again, the
>> install worked fine from the repos (using the same websites) and this
>> time GetCapabilities returned the following
>> "Configuration file problem"
>> as part of an XML payload.
>> Great, I thought, all I have to do is figure out where the
>> configuration file was located and start digging through that to see
>> what's going on. Curiously, I can't find a config file on my system
>> nor any documentation about it.
>> I do understand that the rich variety of configurations of systems
>> makes it hard (well, impossible) to document all possible cases, but
>> I would expect that a default installation of QGIS on a default
>> installation of any of the supported O/S's would just work.
>> Late last night I found another post by "underdark" -
>> http://underdark.wordpress.com/2012/03/30/qgis-server-on-ubuntu-step-by-step/
>> - that I'm about to try. Maybe third time will be the charm! :)
>> I'll take a look at your other numbered items to see if I can make
>> sense out of them.
>> Thanks again.
>> Bo
