[Qgis-user] natural earth projection and qgis?
David Fawcett david.fawcett at gmail.com
Wed Feb 6 18:26:54 PST 2013
I am glad that you figured it out.
You can always get the version from the gdal utility too:
david$ ogrinfo --version
GDAL 1.9.0, released 2011/12/29
On Wed, Feb 6, 2013 at 7:34 PM, Chris Henrick <chrishenrick at gmail.com>wrote:
> no worries,
> I tried in bash:
> $ ogr2ogr -s_srs '+proj=natearth +wktext' -t_srs "EPSG:4326"
> trade_arrows_4326.shp trade_arrows.shp
> and got:
> Failed to process SRS definition: +proj=natearth +wktext
> then I tried
> $ ogr2ogr -s_srs 'LOCAL_CS["foo", EXTENSION["PROJ4", "+proj=natearth
> +wktext"]]' -t_srs "EPSG:4326" trade_arrows_4326.shp trade_arrows.shp
> and success. I must have GDAL < 2.0
> -Chris
> On Wed, Feb 6, 2013 at 5:24 PM, David Fawcett <david.fawcett at gmail.com>wrote:
>> Sorry about that.
>> It sounds like if you are using GDAL trunk or 2.0, you should just be
>> able to use:  +proj=natearth
>> I tried +proj=natearth +wktext in QGIS 1.8. , but I can't get it to
>> take.  Here is a relevant post on the GDAL list.
>> http://lists.osgeo.org/pipermail/gdal-dev/2012-September/034036.html
>> David.
>> On Wed, Feb 6, 2013 at 7:03 PM, Chris Henrick <chrishenrick at gmail.com>wrote:
>>> hi, not talking about the data itself, I mean the actual projection
>>> called natural earth: http://www.shadedrelief.com/NE_proj/
>>> -chris
>>> On Wed, Feb 6, 2013 at 5:00 PM, David Fawcett <david.fawcett at gmail.com>wrote:
>>>> http://www.naturalearthdata.com/features/
>>> -Chris
URL: <http://lists.osgeo.org/pipermail/qgis-user/attachments/20130206/8639c55b/attachment.html>
