[Qgis-user] QGIS Server 1.8 getPrint returns empty map
Bernhard Ströbl
bernhard.stroebl at jena.de
Wed Feb 13 02:08:52 PST 2013
Hi Anita,
please check if it is related to this problem
http://hub.qgis.org/issues/5782
I also remember a decimal-separator problem with QGIS 1.8 (which applies
if you are using the German , in your system's settings and thus in the
composer). Marco Hugentobler fixed that but I am not sure if the fix has
been backported. So maybe you should update your server to current master.
Bernhard
P.S. the url you provided had a timeout
Am 13.02.2013 10:43, schrieb Anita Graser:
> Hi,
> I have a QGIS Server 1.8 instance running and trying to use getPrint.
> I manage to get a PDF with the labels I created in composer and the
> legend displays correctly but the map is empty (just the frame is
> visible). I've posted the request below. CRS and extent should be
> correct. I don't understand the width and height parameter in this
> case though. Is there something obviously wrong? Should it work in
> 1.8? Maybe I should note that the WMS works fine in my OpenLayers web
> client.
> http://10.101.21.28/cgi-bin/qgis_mapserv.fcgi?MAP=/usr/lib/cgi-bin/vienna/vienna.qgs&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetPrint&TEMPLATE=Composer
> 1&map0:extent=16.1,48.0,16.6,48.4&BBOX=16.1,48.0,16.6,48.4&CRS=EPSG:4326&WIDTH=1467&HEIGHT=729&FORMAT=pdf&DPI=300&TRANSPARENT=true
> Best wishes,
> Anita
__________ Information from ESET Mail Security, version of virus signature database 8004 (20130213) __________
The message was checked by ESET Mail Security.
http://www.eset.com
