[Qgis-user] Rotated pole projection: Netcdf
Etienne Tourigny etourigny.dev at gmail.com
Fri Feb 15 08:06:11 PST 2013
Hi Carlos,
You will get more information on the grid itself if you try
gdalinfo NETCDF:"dust_sconc_00_02.nc":dust_sconc10
Unfortunately, the rotated pole projection is not supported by the
gdal netcdf driver.
Please try to reproject/remap using the cdo command-line utility[1]
You should try something like
cdo -f nc remapbil,<grid> in.nc out.nc
where <grid> should be replaced by a valid grid description such as
"r360x180" for a global 1x1 degree grid.
See the cdo reference for more details (1.3.2. Grid description)
You can also try the other remapping operators, depending on your data.
[1] https://code.zmaw.de/projects/cdo
On Fri, Feb 15, 2013 at 10:40 AM, Carlos Camino González
<caminoccg at gmail.com> wrote:
> Hi all,
> I have many netcdf with rotated pole projection, I would like to proyect
> these netcdf to a WGS84 or similar projection, in order to see correctly
> into QGIS.   I tried with gdal (gdal_translate), r.in.gdal with grass and
> different libraries with R, such as raster, ncdf, etc .. But nothing  ....
> is it possible ???
> Could someone give me  the correct code or the solution for this problem?
> For your information, this is the header with gdalinfo -h
> Size is 512, 512
> Coordinate System is `'
> Metadata:
>   NC_GLOBAL#_FillValue=-32767
>   NC_GLOBAL#Conventions=CF-1.2
>   NC_GLOBAL#Grid_type=B-grid: vectors interpolated to scalar positions
>   NC_GLOBAL#Map_Proj=Rotated latitude longitude
>   NC_GLOBAL#missing_value=-32767
>   NC_GLOBAL#NCO=20130201
> Subdatasets:
>   SUBDATASET_1_NAME=NETCDF:"dust_sconc_00_02.nc":dust_sconc10
>   SUBDATASET_1_DESC=[29x1x139x191] dust_load (32-bit floating-point)
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,  512.0)
> Upper Right (  512.0,    0.0)
> Lower Right (  512.0,  512.0)
> Center      (  256.0,  256.0)
> Thanks in advance for your answers !!!
> Carlos Camino
> Carlos Luis Camino González
> Qgis-user mailing list
