[Qgis-user] QGIS is chosing the wrong projection when opening shapefiles
Andre Joost
andre+joost at nurfuerspam.de
Tue Feb 19 06:56:31 PST 2013
Am 19.02.2013 13:55, schrieb James Stott:
> QGIS is reporting that a layer that I know is in EPSG 25833 (ETRS89 /
> UTM zone 33N) is in EPSG 3006 (SWEREF99 TM).
Both have the same proj string, so it should not matter.
If you save the file from within QGIS, it creates a .qpj file where the
EPSG code is given. Next time it will open correct. Otherwise,
rightclick -> Set CRS for layer.
ESRI don't give the EPSG code expicitly in the shapefile.
HTH,
André Joost
