[Qgis-user] QGIS is chosing the wrong projection when opening shapefiles
Andre Joost andre+joost at nurfuerspam.de
Wed Feb 20 08:04:07 PST 2013
Am 20.02.2013 08:17, schrieb Stott James:
(please answer to the list, so that others can benefit from my/your answer)
 > OK thanks for clarifying that.
 > Is there any way to make QGIS select the correct projection without
setting it manually?
Supplying a <filename>.qpj file is the only "sure" method I know.
Greetings,
André Joost
